Easy Ram Glow mod !
mundivalur
Hi guys and girl-s :) let my know if you need more info !
This is just a small ram worklog
Ram at start
The Mushkin ram ready (and some to much uv stuff:D)
Geil Evo Corsa ready
So what you need is 3mm Acrylic (your color) some cutting tool,sandpaper 200-600grit,buffer or something to polish and patience :)
For the Mushkin, cut it little bit higher and work your way down so it can slide in and polish and more polish = shine !
Now for the Geil Evo you do the same but you need to bend the heat spreader a little bit so you can slide the acrylic in.
Thx the rig is a bit different now :) waiting for a psu ,cables and more then i will make a rig thread :D
