Spare-Flair
- Apr 4, 2003
Ever wish you could just reset your bios easily without having to open your case up, set it down, move wires and parts out of the way, and try to plug in a stupid jumper and then pull it back out with needlenose pliers while probably dropping it somewhere and having it get lost inside your case?
I dumpster dived for an old AT case and ripped out all it's power/reset switches and wired one up to the bios reset jumper pins. Then you just put this switch anywhere you want. Hold it down for 10 seconds and *poof* CMOS cleared!
