And by remotly share I mean something similar to mapping a network drive from one PC to the other.
I need the remote computer to be able to point a program access and use a database file on my PC.
Any thoughts?
Maybe using VPN? Does anyone know a free VPN software and any guides on how to set it up?
Or maybe using IIS?
And I should note that the PC where the files are located is Vista home and the PC where the files are needed is XP Pro if that matters.
Any thoughts?
Or maybe using IIS?
