Easiest, most *Reliable* BU method - disregarding cost ?
aimee24
Not sure where to post - could be hardware or software solution.
I'm looking for easiest & MOST RELIABLE method to BU OS & installed programs partitions, AND the restore or copying BUs to original partitions / HDDs ACTUALLY works.
I just spent days w/ HP printer software / registry issues. HP support was useless this time.
1) Imaging software seems to always have potential glitches. Any new program installed or Windows update, as examples (Vista x 32 / 64) seems to potentially cause BU software problems - Acronis, Ghost, etc. - read the thousands of posts on the subject.
2) I don't care WHAT the best method / solution costs, long as it's easy as possible (scheduled automatic is better), AND most reliable method available.
I'm partially disabled & though have advance ability to figure out almost any computer problem, have NO time or physical ability for such. I have NO time to trouble shoot why Acronis, Ghost, etc., is no longer working / restoring properly.
3) What do IT pros use for simplest, most reliable BU & restore?
4) My desktop has open bays for several more HDDs (but not my laptop). Maybe buying 1 or more giagantic HDDs & just copying the entire partitions & have DOS prgm(s) capable of copying entire partitions back, if windows or HDD fails completely?
For laptop, maybe large external HDD?
Thanks for suggestions.
Get a WHS device (the cheap HP model is actually pretty good).
Set up WHS backups. Its fully automated and trivial to set up.
Restore procedure goes like this: put restore CD into PC, boot it up, restore over network.
The restores are so simple and reliable that I've used it to upgrade the hard drives in my kids laptops - just install the new drive and do a restore. Simplest upgrades I've ever done (and I am a long-time Ghost user).
Better to use a wired LAN as backups over WiFi will take forever.
I use WHS as my backup.
All data is backed up thrice.
Once is the raw image file of the PC that WHS makes.
Then important stuff is also on a share with duplication enabled.
Makes it pretty fool proof. System restores are incrediably easy, even with my RAID on my desktop. I love being able to just restore back to a previous image.
Baring robbery or house fire, I'm covered.
Thanks.
Piglover - are you talking about an HP MediaSmart server like this?
http://www.newegg.com/Product/Produ...re=windows_home_server-_-59-105-503-_-Product
Is there any real benefit to having a box w/ WHS vs the software & a large separate HDD (internal or ext)?
What about the so called automatic BU drives like Seagate free agent or Buffalo LinkStation? like these http://www.frys.com/template/onad/product_navigation/spot5
MrMitch - how easy is it to restore a single partition back a certain time w/ WHS?
Eventually you'd run out of room on the BU drive(s) - then what? Start over?
I've restored image files successfully with BootIt Next Generation...
it has features like,
sound alert when backup finishes
enable usb 2.0 etc etc
image set (do several partitions one after the other).
the only place where it has failed is a sata-on-pci-controller which
has maybe not polished enough code on the bios to handle
fast (?) non-standard (?) transfers. (freebsd.org) + (rsync ) +
(rsync's "bwlimit" parameter) fixed that (you can google the
latter. ) I can browse along while the rsync completes in
the background, incrementally. (Some time to setup.)
(And of course you would/might migrate away from windows or
dual boot with BootIt, that in itself is tricky as freebsd-and-windows
installs have to be done "very procedurally"... or one or the
other loses data.
At least one of the above lines pertinent to the original question
as stated ...
Restore is very easy, just slap in your CD, boot to CD, the CD goes over the network, finds WHS, then yuo select the backup and where to restore. Inside a backup is the individual partitons, and you just click what partition you want and where to restore it to.
Backups are incrimental, so you most likely won't run out of space. The HP media smart supports upto 4 drives out of the box, thats upto 8 TB's with 4 drives.
http://www.newegg.com/Product/Product.aspx?Item=N82E16859105562
Thanks.
You asked for the easiest way and then said that you weren't interested in image-based solutions like Ghost or Acronis. Not many choices left...WHS is probably your best bet.
WHS gives you a pretty good UI to manage your backups. You won't run out of room just from the images.
Yes, the HP Mediasmart is what I was referring to. There are others too, that's just a good example. You can also roll your own, but since you are looking for easy I figure that isn't what you'd be looking to do.
If money isnt a concern, pay a professional to back it up. As for WHS, theres a reason a lot of people here (myself included) run 2 of them, and its not cause we like to. To the other people that replied, you but far too much faith in WHS.
