Easiest Linux to work with
ModestMoo
Hi guys,
I have few linux'es to choose:
CentOS 6 64bit or 32bit
CentOS 5 64bit or 32bit
Debian 6.0 64bit or 32bit
Ubuntu 10.04 64bit or 32bit
Ubuntu 8.04 64bit or 32bit
Which is easiest to work with? Or it depends on my needs?
Thank you
Definitely depends on your needs. If you're looking to get started I'd probably go with Ubuntu for a few reasons, lack of worrying about SELinux being one. Though if you go with CentOS you can certainly set SELinux to permissive, learn the OS, set up a few servers and then enforce it again and have fun fixxing what no longer works.
What will you be using it for? Just learning?
Are you looking to use this as a desktop or server enviorment?
What exactly are your needs? Do you want a GUI, or is this pure shell access?
Decide what you need Linux for first. Alot of enterprise apps will be targeted at RedHat (Fedora Core) or CentOS.
Windows desktop replacement will probably be Ubuntu or RedHat.
If you have a specific app in mind, look at what they support. If you have a specific field in mind (web hosting, rendering, DB, etc) look at what is common in the industry.
If you are just starting out and want to get your feet wet, it's all experience so you probably can't go wrong.
I'm just starter, but soon I'll need to install software needed for few users to run on individual server.
If you are practicing to do a server in the future, find a CentOS minimum install and start from there. Great place to start and learn from command line only
I would install Ubuntu on a laptop and get comfortable installing packages from command line and just working in general from the command line as well as using Linux day to day. Then move on to installing CentOS as a server and work from there. From my experience Linux is much easier if you "wade in" instead of "dive in"
Lightweight :) I dove in and did centos and it was worth it. Struggled for sure but it was a great learning experience
1). Have you considered what type of file system you want to go with?
2). Why is this an important question to ask yourself?
These questions should help point you in the right direction ...
Teaching you to fish ....
Ubuntu or Debian, both are very good.
Ubuntu have GREAT wireless & laptop support, Debian is a little pickier on the wifi stuff..
apt -get = wicked :)
Easiest LInux? thats an oxymoron right?
HAH. I hear its Mint or Ubuntu these days?
You're really not going to go too wrong with any of them.
However, my personal recommendation would be for Ubuntu, because it's relatively easy and there is documentation for DAYS on it for whatever you might want. Want to install dovecot? No worries, docs several blog posts. Ruby on Rails? Not a problem, several docs and blog posts detailing exactly how to get up and running.
Default file system at this point should do fine. Probably ext4.
