EASEUS Disk Copy - Anyone Use It to Clone?
RhoXS
For many years I used DOS based Ghost 2003 to regularly clone my primary hard drive. It was simple and worked very reliably to make plug and play backup drives. Sadly, since I converted to W7 and a SSD primary drive, tried and proven elegantly simple Ghost no longer will make a plug and play clone.
All the current products must be installed in Windows, and, in my opinion, are unnecessary resource hogs, taking up too much precious SSD space. Also, I am not comfortable making a clone from software running on the same drive I am cloning. I prefer a product that does not get installed in Windows but have not yet found one. Running from either DOS or a bootable CD is my strong preference.
I just stumbled into two EASEUS applications today.
Must EASEUS (Todo Backup or Disk Copy) be installed in Windows or can it be run from DOS or a bootable CD?
With Disk Copy, you burn a bootable CD. The download is actually an ISO.
I used it to clone my Win7 Pro x64 install back and forth between my laptop's HDD and SSD when I was switching. They both happened to be 80GB, so I can't comment on how well it works with drives of different sizes, but it did maintain proper partition alignment, with the hidden 100MB partition on the drive.
