Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Since newegg is selling the Antec Earthwatts 500W PSU for $45, I'm thinking about jumping on this deal for me new system. Is this a sufficient PSU for my upcoming build?
Q6600
Geforce 8800GS
3 Sata HDs
DVD burner
4 gigs PC6400 RAM
5 120mm fans
I'm considering buying that PSU for a similar build, and wondering the same thing. I hear they are built by Seasonic and overall a pretty good PSU in terms of efficiency.
The thing that worries me is that this only has 1 80mm fan on the back, so not sure how hot it runs. But spec wise, it is extremely similar to the Seasonic 500w (why shouldn't it be, it is SS built after all), which is a very good and stable PSU.
