EA??CRYTEK?? copyright??
Light-tower
I've been trying to contact these guys for sometime. Need permission to use some of there artwork. Does anyone know anyone over there that I can reach?:confused:
If its for a website, they probably have a fan kit that you can use, also as long as you give them copyright notice and don't try to claim their stuff as your own, you should be ok.
Yeah they probably won't care as long as you give them a copyright notice on the website. As far as your case, just do it and make it look great :) I don't think they would ever try to get a fan in trouble with the law over copyright stuff unless they were trying to claim the images as their own.
You could always contact them here:
http://www.crytek.com/contact.html
Try emailing with that form or emailing their marketing department?
Yeah I did both with no replies, even tried there forums. I sent another one out so hope they'll reply :)
Well if you tried and they never replied (hey that rhymes :p) then I'd just say go for it. If they do have a problem they will just ask you to remove the images most likely.
i got a notice of copyright infringement for using their logo (ea) in a post I wrote about crysis
