Dez Perado
- Sep 25, 2007
The E8600 is showing in stock at J&R and CompSource.
The E86 is 3.33, and it's the first duo with EO stepping.How does this compare to the E8500?
Does anyone know if the temp sensors on the E8600 work good or are they still getting stuck like the E8400 also?
I know required voltage is a HUGE difference, I would assume thermals would follow...
Check out XS forums - they're getting some crazy OC results from these things. It's NOT just the multiplier or the E0 stepping. Intel IS binning these things.
