Hello.
I have a problem with my new computer, my cpu temperature is much higher than it should be.
Rig: Sonata 3 with earthwatts 500w psu, e8400, 4gb ram, asus p5q
Cooling:
cpu: Noctua NH-U12P (yes, I know how to apply thermal paste properly and have followed the installation instructions carefully)
gpu: accelero s1rev with a zalman zm-f3 fan running on maximum rpm (1800rpm)
front case fan mounted in HDD rack because it wouldn't fit behind the graphics card: 120mm 800rpm noctua (NF-S12-800)
rear case fan: 120mm 800rpm noctua (NF-S12-800)
psu fan
The front case fan is used for air intake and the psu and rear case fan are used for air output.
The gpu fan and the cpu fan blow in the same direction: upwards towards the psu
Cpu voltage is set in BIOS to 1,15V, FSB is 400 (e8400 @ 3,6Ghz) and ram are set to run according to their manufacturer specifications. Nothing else has been modified in BIOS.
I'm testing the system running both Orthos small FTTs and ATITool at the same time for maximum stress.
My problem: I get a very crappy 70C temperature at a mere 1,15V, despite having invested in a high end cpu cooler and having decent airflow.
My guess is it's a false reading, at least that's what I hope it is. I can't see what else it could be. I have tinkered with this computer a lot and I don't think there's anything else that could cause this heat.
Here's a screenshot of my desktop during the stress test (after running 1hour 10min).
http://koti.mbnet.fi/maxz/temperature.jpg
Any help is greatly appreciated.
edit: I already have the latest BIOS downloaded from the Asus site.
Cooling:
psu fan
