Whats the packdate on your good chip? My packdate is 01/09/2008 and coretemp has a bit of flucuation (not as bad you what you describe) and Core0 is always cooler than Core1... which is strange.
It's all in the sig guys, 1/15/08 pack date.
See what you guys think of this.
According to Abit uGuru my System Temp is 31C. SpeedFan reads my Ambient as about 41C
Reading from CoreTemp:
My E8400 idles at Core0: 27C, Core1: 26C
As soon as I turn on Orthos, Core0 jumps to 34C and Core1 jumps to 35C with in 1 second of Orthos starting.
Core0 maxes out around 44C and Core1 at 42C
Does this sound right?
I'm using the Thermalright Ultima-90 with a 120mm Scythe S-Flex fan and AS5.
Didn't bother reading the rest of the thread but I put together my Wolfdale build yesterday with the stock heatsink (for now) and am getting ~50c idle, 65c load (orthos) using Core Temp 0.96.1 (which correctly identifies my CPU).
Well, after double checking the heatsink, i found my problem. When i first installed it, only 2 of the tabs popped in, while the other 2 went into the motherboard, but never "clicked" in. I was a little afraid to push them any further before, because it was bending the motherboard a bit, and i didnt want to crack the thing.... Anyway, now the e8400 is idling at 26C (acording to the bios) but core temp says its 51c. Either way, its much cooler then before. For people who are able to OC their 8400 to 4ghz+, which do you use to monitor the CPU's temperature? Core temp, the bios, or something else?
Add about 8-9C to your CPU temp and that's your Core Temp. That's how it pretty much is on my Gigabyte board with the Q6600 at least. That temperature reading is being pulled straight from the BIOS. The CPU temp always seems to be about 8-9C behind the average core temps.
I pointed an IR thermometer at a bare E8400 core all the way up to 100C and discovered that TjMax for these processors is 95C and not 105C that CoreTemp is assuming. Here's the long winded version that I posted on XS:
http://www.xtremesystems.org/forums/showpost.php?p=2763280&postcount=1259
http://www.xtremesystems.org/forums/showpost.php?p=2765889&postcount=1308
http://www.xtremesystems.org/forums/showpost.php?p=2766465&postcount=1328
If you don't have time to read then use CoreTemp and subtract exactly 10C from the reported core temperatures. Your temps will now be 100% accurate from 60C to 95C. No software will be 100% accurate below 60C because the DTS is not now and never has been accurate for reporting idle temperatures. Intel did not design or calibrate it for that purpose. Air cooled idle temperatures might be off by +/- 5C or even more after the above correction. During testing 40C reported was 35C actual.
If your load temps never get up over 60C then your temps will never be 100% accurate if you use software like CoreTemp that reads data from the on chip digital thermal sensors. Only the mobile 45nm chips have an Intel documented TjMax=105C. My testing shows TjMax=95C for the desktop 45nm dual core processors.
If your E8x00 is suffering from the stuck sensor problem where temperatures don't move whether at idle or full load then you are screwed and there is nothing you can do. No software is going to work properly. Garbage in = garbage out.
The problem is that you don't know where the "cpu" temp is coming from. The only on-chip sensor is the DTS, which coretemp reads, so the BIOS (and motherboard) are getting that CPU temp somewhere else - probably a thermal sensor around or maybe under the socket. But without knowing what that sensor is reading you don't really know what a safe temp is. Intel's Tcase, which is what their max temps are based on, is measured by putting a sensor right on the top of the heatsink, which is pretty much useless for any real world applications.
That is good news - makes temps like mine seem a lot more reasonable. Lot of people have really low coretemps though (like 50s load) - I wonder if those are accurate as they seem too low to be true when you subtract 10 from them. I'm guessing your IR thermometer is correctly calibrated and all?
Can I ask a quick question? I'm looking at putting together a new rig in March and was looking at the E8400. I'm now a little worried about motherboard support and some of the other issues with this chip. Would it be worth it to pick up a cheaper CPU for now, like an E4500, for now and then just getting the 8400, or the Q9450, when some of the wrinkles are ironed out? Or should I just drop the additional $30 or so and pick up a Q6600? This would be mostly used for gaming with an occasional DVD rip.
I'm upgrading from an old Northwind 2.8 so even the low end part should still be a temporary boost. I was going to get an E6750 but I thought the ~$40 more for the E8400 would be worth the extra cash.
Thanks in advance.
Thanks in advance.
Right now according to CoreTemp Core 1 is running at 47* and core 2 is running at 52*. Should there be that much of a difference between the two cores? Could I have applied my thermalpaste wrong? Or is this normal?
This is my first dual core so sorry for the newbish question.
It's fine for them to show a split, seems like a lot of the E8400s do it.
For those that still need a number to compare to here is my temperature. My E8400 at a room temperature of 21C when running Orthos small FFTs at 4050 MHz and 1.368 volts in a fairly quiet, closed well ventilated case with two exhaust fans using a Tuniq tower with the original fan at its minimum speed of 1188 rpm will load at about 65C based on TjMax=95C which is 30C away from TjMax for those that don't believe my TjMax=95C findings.
try to google the exact thread title "E8400 Temperature problems " u'll find alot of usefull links (I hope yorkfield will not have the same problem)
I was wondering if these screwy temp readings are screwy at default clock speeds, as they are with oc speeds ?
I won't be upgrading any of my pc's to 45nm until I can get some accurate and consistent temperature readings. Say what you will, but this is not something that should be hard to accomplish, and I do think that Intel will be correcting this soon.
I mean, if some of the temps I've been seeing are even close to accurate, then the whole bit about 45nm running sooooo much cooler is a farce so far.
...it's just a temp sensor, it's been spot-on for a while now.
