E8400 Tempature on 780=(((((( help!
Sewy18
Hey guys is the E8400 tempature problem fixed yet?
Core temp reads my cpu at 40-45 idle
Real temp reads my cpu at 30-35 idle
What can I do?
coretemp is usually considered the most accurate monitoring program since it reads the actual die temperatures. Real temp is probably reading external. Try reseating your heatsink if thats possible... maybe using AS5 if you have some
Real temp reads the internal just like Core Temp. The internal Intel DTS only records the temperature margin from Tj Max in internal registries. Applications guess at what Tj Max is to calculate the actual temperature. Sometimes there is variation in their guesses of what the Tj Max limit is thus it effects their temperature reading guess.
Go into Core Temp's setting, set it to show the delta temp to Tj Max.
Then compare that with what Real Temp says is the distance to Tj Max.
Also, compare what each program thinks the Tj Max value is.
Can someone please explain to me how this distance to tjmax works ?
When i enabled it in core temp it says
Are these good temps while idle?
Tj max 105C
Core 0 63 cto tjunction max remaining
Core 1 65c to tjunction max remaining
What does this mean?
thanks for the help
Tj max 105C
thanks for the help
Tj Max is the max safe operating temperature of the CPU.
Distance to Tj Max is how far below that maximum threshold you are.
This value is all the Intel CPU's measure and store.
The limit, the actual Tj Max value is not clearly published so Core Temp, and RealTemp guess at it, then give you a calculated temperature for your CPU.
[Tj Max approximation] - [measured distance to Tj Max] = CPU Core Temperature
So... back to my previous question. Does Core Temp and Real Temp agree on Tj Max. Do they agree on their readings of Distance to Tj Max.
Yes 60C to Tj Max is VERY low.
Thanks man yah they both agree exactly on the tjmax ,what does that mean?
Strange... Load it up with Orthos for awhile. What is max load temp? Does it correlate accurately between the two apps.
lol something is seriously scrwd up
Both tjmax are exactly correct
Real temp, while under orthos =cpu core0 - 40c cpu cor1- 41c
Core temp ,while under orthos=cpu core 0- 47c cpu core1-50c
Very strange. You didn't try running any of the calibration options for RealTemp did you? Redownload the latest version and unzip and run it fresh.
Both should be reading the same distance to Tj max values.
