Running real temp right now and I have see the temperature diffrence between the two cores be as much as 14 degrees? sometimes it is less, other times it is more, on average the two cores stay about 10 degrees diffrent.
For example I am just sitting here with nothing else open except for this IE window and one core reads 41 wihle the other reads 28? Right now I am running @ 9x400 for 3.6 with vcore set to 1.275. board is a GA-EP35-DS3L cooler is a Freezer 7 pro. I didnt want to bump the voltage up on the CPU but it wouldnt go through prime 95 or other torture tests without the bump. I havent gone past 1.275 yet.... but have tried higher FSB lol.
I took my system back apart to make sure the heatsink I had was on and tight and all seems good, I havent experienced any crashes or etc as of yet..... (knock on wood!!)
Just seeing if this is rare but normal or what. Peak temps I have seen are 54 and 48
BTW this is all in a HTPC case along with 2x 1GB and 2x 512MB OCZ mem that has to run at freakin 2V and a 4850 stock cooler. temps seem pretty good (even though the 4850 did run as high as 85 under load, I have the fan set to 40% now and I havent seen it go above 70 yet)
