Hi all
I am looking to build a new computer in a few weeks.
I have picked out everything I will need. Not going do any overclocking. the one thing I am unsure on is the stock heatsink for the e8400. Should I replace it right away or is it good enough.
I will pair the e8400 with intel DP43TF motherboard, nvidia 8800 gt and 2 gigs of ddr2 800 mhz ram, with vista 32 bit
If I need an aftermarket fan which one is the best.
I am looking at http://www.newegg.com/Product/Product.aspx?Item=N82E16835106124
I have used their V1 design which is the same idea but was made out of copper.
thanks again
thanks again
