I've been putting some ideas together for a new system build and I want to give the e8400 as much overclocking potential (with only air cooling) as possible. Reccomendations from general hardware thread were:
MB: GA-EP43-DS3L http://www.newegg.com/Product/Product.aspx?Item=N82E16813128347
HSF: XIGMATEK HDT-S1283 120mm Rifle with Retention Bracket http://www.newegg.com/Product/Product.aspx?Item=N82E16835233003
Memory: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory http://www.newegg.com/Product/Product.aspx?Item=N82E16820231145
Case will be a well ventilated antec, gpu an hd 4870, would I be able to pull a stable 3.6 out of this before I pull the trigger?
Original thread for reference: http://www.hardforum.com/showthread.php?t=1331698
Thanks for any helps
