E8400 Degraded (It's really true!)
Mine is running comfy at 1.2v @ 3600 Mhz with temps no higher than 43ºc
Im quite happy :)
Wouldn't risk going higher than 1.3v
@Sem
My CPU was so bad, that it wouldn't boot @ stock @ stock vcore. It should have seen it coming when it wouldn't listen.
@Brownstone:
Unless I hit the 3.8 mark, my GPUs are bottlenecked really bad. And my first E8400 (which I took a risk and exchanged for this one) would do 4.0 @ 1.3.... what is your VID btw?
FALSE ALARM!
My system not booting up was due to a stupid SATA cable being half plugged in.... I don't know how the hell that happened, but im back up to 4.0GHz @ 1.48 :)
yeah. i feel like shooting myself because i spent the past 5 hours trying to figure how to use my system till then.
back to crysis it is :)
lol go user error.
I personally dont bring my e8400 over 1.4V, which is how much it needs to reach 4ghz, damn bad batchs lol
Well, all's well that ends well... and you're back up in the high numbers... so result! :)
An old racing saying:
Its not the car that's the problem, its the loose nut behind the wheel.
FALSE ALARM!
Noob alert! :) j/k...
But seriously, just edit your first post.... (delete it) then lock the thread!
hahaha. well i didn't even freaking touch the inside... it somehow came loose by itself :p
14k Vantage :)
