I've been searching for results for my question, but cant find any.
I'm torn between the E6850 and the Q6600... Help!
if you use your computer solely for gaming then you are right sir.For the money E6850 will easily beat quad core in all games out now and for most games in the future. There will only be a few games in the near future that can even use quad core. I bought single core AMD64 because I knew that would give me the most bang for the buck. It's only now I am ready to buy dual core and even that doesn't bring much to the table. 2 cores doesn't equal twice as fast even in games and apps that can use dual core. Some dual core enabled games it makes only a few percent difference. Quad core is certainly nothing to get excited about.
What most of you guys miss is that the Q6600 as well as the E6850 in games right now will make next to NO difference in performance if you look besides the multiple cores. In essence, no game right now is as CPU dependent to make an impact between the two one side or another. If you then count in that a couple games come out that support multiple cores, the Quad has a distinct advantage.
What i mean is that sure, in a resolution of 640x480, the E6850 would smoke the quad in single core games, but most games we play is not 640x480 but 1280x1024 or 1600x1280 or 1680x1050 or higher. There you have a videocard limitation and not a processor limitation. Both CPUs will perform very close to each other in these resolutions or it doesn't make an impact (because the FPS are so high in first place).
S[H]ady;1031266249 said:You don't need a single piece of software to use the whole CPU. thats not what multicores are for. They are for doing multiple tasks symultaneously as fast as possible.
Well the Q6600 for CAD and e6850 for Gaming.
so if i do a lot of graphic design work, and movie editing, should i buy a quad instead of dual??
S[H]ady;1031267590 said:Yes.
quad core is much faster in the vast majority of video editing software.
Cad will also likely take advantage of quads as well.
3D modeling software certainly does.
But you give no reason why. I care more about how my older games will run than I do about new games in the pipeline. I am interested to know why you think this as I am buying a new cpu soon. I might change my mind about the E6850 and go quad if you can give me a compelling reason to. I doubt you can give me a compelling reason though.from a gamer's perspective i would still get the quad core.
I have this feeling that Crysis will run faster at high res on a Q6600/X3220 then a E6850 everything else being equal of course.[H]ardOCP should do a article on this.Maybe then get Crytek to help with a late build of the game.
Like Anandtech did with UT2004 years ago...
Take a look at my sig, thats my current spec. I just want to increase framerate. I just got a Samsung 226BW monitor... I was running a monitor with 1440x900 before. But now with the new monitor im running @ 1680x1050. I have noticed a drop in framrate a fair bit.
Is this really true. I specifically am looking at both chips but 95% for gaming. When I looked at the benchmarks I was quite surpised to see that quad core on one websight was not doing as well as the 6850. Why? It was actually getting less fps. I'm so split on this that I want maximum framerates but also want crysis to run as fast as possible but not if quad is only going to bump it up and average of 5 fps on the minimums.
CoW]8(0);1031267467 said:Just curious, what's your framerate now?
good point, but aren't the current quads very crappy ones? In the future when people look back wouldn't they just be like the pentium Ds of quad cores?S[H]ady;1031267590 said:Yes.
good point, but aren't the current quads very crappy ones? In the future when people look bad wouldn't they just be like the pentium Ds of quad cores?
are the current quads a lot hotter and harder to overclock than the e6750/6850s?Well quads will get better, but nothing has been better.
Yep, buy a long way.
hmm, i have just been searching up the forum all day today about quads vs dual cores, seems like no one have a definite answer on either go to for a e6850 or q6600 lol
but i believe i read some where that the new q6600 released after july 22 are gonna be G0 stepping, which means they SHOULD run much cooler than the previous ones? if thats the case i would really reconsider and maybe get a q6600 instead, because i do a lot of video editing and photoshop etc
