E6750 TJunction Max
PC_User
How do I find out the TJ Max for my E6750? I am running Core Temp which shows the temperatures as 5 degrees C higher than Real Temp. I believe Real Temp has a TJ Max of 95C while CoreTemp is 100C. I checked BIOS and the BIOS temps are closer to Real Temp. How can I find out which is correct? Most other programs (SpeedFan, HWMonitor, etc) show the same temps are CoreTemp.
Personally I trust Real Temp more, although I have never heard of Real Temp and other temp programs disagreeing on 65nm processors. Usually there has only been a problem with the 45nm processors because TJmax was changed between them.
Always love it when first party companies/manufacturers use third party stuff :D
RealTemp is using TJMax=100C for your processor now like every other program. Intel plans to release TjMax data for 65nm at the next IDF forum. Go to Google and type in realtemp beta and it should take you to the beta site at the fileden for the latest realtemp release.
The TjMax spec might be exact but there is an unknown amount of variation in TjMax and Intel hasn't disclosed that yet and probably never will.
