Oct 31, 2007 #1 S Shivetya Limp Gawd Joined Jan 24, 2005 Messages 245 Looking at mostly use for gaming, go for the fast dual core (2.6) or get a quad core (2.4) ?
Oct 31, 2007 #2 C Charger69 Limp Gawd Joined Sep 30, 2005 Messages 145 Q6600 for sure. You can O/C a Q6600 if you are concerned with speeds fairly easily. Additionally, the Q6600 is not much slower than your E6750.. Quad rocks!
Oct 31, 2007 #3 mattchapman Gawd Joined Dec 30, 2005 Messages 572 If you're not an overclocker I've read that the E6750 (or 6850) is the best (fastest). Go for quad core if you can overclock or have someone do it for you.
Oct 31, 2007 #4 C CRXican [H]ard|Gawd Joined Jul 28, 2004 Messages 1,962 try looking in the correct forum http://www.hardforum.com/showthread.php?t=1235326
