E6750 Oc Help!
kc690
Ok so far I have been able to reach a 450 fsb stable with these settings:
Cpu Voltage: 1.4
Ram: 1.95
Nb/Ht-link: +0.25
FSB: +0.25
south: +0.20
VCC12: +0.10
Temps are 39 idle 60 Load.
Any attempts I make at getting it past this results in me having to reset the mobo. Any suggestions on achieving a higher fsb?
That's about where I am. 450 x 8 = 3.6GHz
I am sure I could eek out 200 MHz but at the cost of mucho voltage and heat.
I run 3.6 all day at reasonable temps.
What if I start lowering all of my voltages, if i find out what one I can not lower much is that the one that is holding me back?
I'm at 1.44vcore and 440fsb on my 6750...no luck getting it stable any higher. Then again the only voltage I have touched is vcore...my temps are about 30-35idle under load.
