I have an Aspire Xplorer case with an aspire 3 fan PSU suckin hot air out, 2 80mm intake fans at the bottom, 1 80mm fan at the top sucking air out, 1 80mm fan blowing air at my Zalman 9500 which also has its fan on, and finally a 120mm fan in the back.
E6700 @ 2800mhz
PC Probe 41 (c)
Asus AI suite 41 Motherboard Temp 39/40(c)
Core Temp 43
These are my E6700 idle temps. My plan was to OC more but i want to make sure these temps are ok because i was having doubts and i dont want to have a 3ghz speed with 55 idle or somethin.
If they seem high is it because i put too much AS5 on my cpu or cuz it hasnt set because i built my rig 4 days ago.
Or are they high because my fans arent doing their job?
If i need to do more tests tell me which ones k
E6700 @ 2800mhz
PC Probe 41 (c)
Core Temp 43
