E6700 and Intel D975XB
marrt
What memory should I use with an Intel e6700 and an Intel D975XB board? I don't plan to OC at this time...just looking for max stability. Is this MB sensitive to voltage like some of the other Intel boards? And, as usual, price is an issue.
You would probably want DDR2800 dimms that run on 1.8v just to be safe then. Intel is known to be picky about voltages.
no the bad axe is a very stable board and has a voltage range from 1.8-2.2 with mods out there to increase the voltage.
If you don't plan to OC at all, just get DDR2 533 to keep the FSB:RAM 1:1.
Sorry for the noobie questions...but if I get 667 or 800, I will not see any significant benefit unless I OC...correct? Otherwise, I should just get the fastest I can afford to preserve the option to OC in the future?
