e6600 vs. 1066 ram
Moddest Mouse
I'm debating what i should upgrade to and i need some help. should i get a new processor (e6600) or the patriot 1066 RAM? i'm trying to get the maximum overclock possible. if i get the 1066 i can push my proc much higher, and im getting liquid cooling so i know i can handle a good bit of heat. but if a get the new proc then i could get the processor pretty freakin high.
what would you guys do?
RAM. The processor is essentially the same thing as the E6600, only it has less L2 cache. You can probably push it very high, and assuming you don't hit a FSB wall, you will be golden. Besides, if you get that thing to 3.6+, what more could you really need?
