E6600 temps?
draxxus13
Well i got my self a E6600 and P5W DH Deluxe mobo
and the cpu is running on water (koolance exos-2)
the temps i am getting are a little wired Core temp is saying 41C core 1 37C core 2
everest says same, and AI Booster says 27C even when oc'd to 3ghz temps are same
any ideas?
specs are
E6600 B2 steeping
Asus P5W dh deluxe
1707 bios
4GB ocz DDR2
As per 100's of other threads...
Core temp is most accurate.
A difference in temp between each core is normal.
intel TAT is the best program for loading/temp monitoring a Conroe.
