E6600 Overclocks. Post your settings here!
I know there are all these other threads (and the big all C2D OC thread) but I'm looking for some specific E6600 settings for successful Overclocks.
I have everything in my new build picked out except for MOBO and RAM (will get the E6600)
If people could post in this thread their E6600 Core2 Duo setup and any relevant settings and their successful Overclocks it would be greatly appreciated.
I dont know what all categories to include, suggestions welcome!
CPU
-stepping
-voltage
COOLING METHOD
-and brand if HSF
MOTHERBOARD
-bios version
RAM
-Brand
-Mhz
-voltage
-timings
successful overclock results.
E6600 OEM (not ES)
-B2
-1.45 Vcore
-week 25
Air
-Scythe Ninja Plus
Gigabyte GA-965P-DS3
-F4 (final) BIOS
Corsair XMS2 DDR2-800 5-5-5-12 (PC6400)
-1.9 Vdimm (had to set +0.1v in BIOS)
I'm running 356x9 now (3.2GHz). This is as high as I could get with dual prime stable and not increasing the Vcore any more than 1.45v (I did it a few times, but the temps were too high, 60c under orthos).
Can someone help me with my e6600 and P5B? I'm new to overclocking and want to get the most performance out of my system.
The system is:
E6600
Scythe Mine
Asus p5b (latest bios)
Corsiar XMS2 DDR-6400 Cas 5
I tried pushing the FSB up by 25mhz but the system woudnt boot. I'm guessing I need some kind of memory divider but i'm not really sure.
Any help would be appreciated. If someone with a p5b could list their settings, that would be great.
Jeff
E6600 Retail
-B2
-1.3625 Vcore
-week 25
Air
-Zalman CNPS9500
Motherboard
Asus P5W DH
-1101
Memory
-Corsair XMS2 DDR2-800 5-5-5-12 (PC6400)
-Stock Voltage
I'm running 333x9 now (3.0GHz). Orthos dual stable after several hours, 50c mb temp, 29c idle, 41c load. I may try to go higher, at the moment the only settings i have changed are Cpu vcore voltage (+0.04) and the fsb (333).
E6600 OEM
- B2
- 1.325v
Scythe Mine
Asus P5N32-SLI SE
- 0204
OCZ PC2-8000 Gold XTC
- 1000 mhz
- 5-6-6-15 @ 2.2v
2700 (9x300): Thats about as high as these nforce 4 chipsets (for intel at least) go. The chip seems to have a ton of OC room left, but i'm limited by the board. Guess thats the price you pay if you want "official" SLI :) Still incredibly fast. I'm amazed the memory is stable at 1000mhz!
CPU - 6600 OEM
Stepping = B2
voltage = 1.38
COOLING METHOD
Scythe Infinity
MOTHERBOARD
Gigabyte DS3
F10 - official
RAM
G.Skill PK DDR2 800 4-4-4-12
@ 833Mhz (2.5 ratio)
+.01v (1.89v)
4-4-4-12
successful overclock results:
3.0Ghz orthos 24hrs stable
(9x333)
3.2Ghz orthos stable (8x400 with F7 Bios & 1.45v, but wasn't stable with F10 bios)
also I added a 40mm fan to NB
- E6600 Retail
- B2 Stepping 6
- 1.47v
- Scythe Ninja & Noiseblocker SX2Pro Fan
- Asus P5W-DH Deluxe (Bios 0701)
- 2Gb G.Skill PC2-6400 HZ
- 390MHz 1:1
- 2.15v
- 4-4-3-8
Currently running 3514MHz (390MHz x 9), completes 24hrs dual Prime 95 no problem and scores 10,017 in 3dmark06 with a 7950GX2 @ 600/1520.
Temperature is 58°C under load with a 34°C Case Temp. The chip will run 3601MHz at 1.53v but gets to 64°C which Im not comfortable with.
Now thats the type of clock I was REALLY hoping for. Thought I will be happy if I can squeeze out 3Ghz. The 40mm fan for my NB is on order, but won't be in until Weds.
Nitro16 said:
- E6600 Retail
- B2 Stepping 6
- 1.47v
- 390MHz 1:1
- 2.15v
- 4-4-3-8
nice o/c, i guess your 4-4-3-8 RAM kicks my 5-5-5-12's ass
- E6600 Retail
- B2 Stepping 6
- 1.4v
- Zalman 9500
- Gigabyte DQ6 (F3)
- 2Gb OCZ PC2-6400 XTC EL
- 356 1:1
- 2.25V
- 4-5-4-14 (can tighten I'm sure)
I am still workin on this, my only prob is up to about 385FSB my board craps out and just won't post. Relax the ram, raise FSB/MCH volts, nope, doesn't budge, tried the different F3 bios', just gives me shit.
Still, 3204mhz on 1.4V is alright. Testing it right now on 1.375V, reckon its gonna do ok. Nice little chips, 800mhz overclock is better than the 300mhz I could get on my old AMD 4400, thats for sure.
Oh and pic for proof
CPU:
Core 2 Duo e6600
2.87 GHZ (normal 2.40 GHZ)
1.3625V
FSB 1275 MHZ
Cooling:
Water
Thermaltake Armor LCS
CPU Temps:
Idle: 35-42 C
Load: 44-45 C
Video:
2 XFX GeForce 7900 gs
600 MHZ
Motherboard:
ASUS P5N32-SLI SE Deluxe
Nvidia NForce 4
Memory:
OCZ Special Ops
800 MHZ
Hard Drives:
Segate 160 GB 7200 RPM
Segate 400 GB 7200 RPM
I got a 5.5 Vista Experience Score because my primary hard drive (160 GB) only has an 8 MB buffer and my memory is not overclocked as of this writing.
Can anyone please tell me if you get a better score than me.
Thanks.
CPU:
E6600-Retail
L629B365
1.15v@3.1
HS/F-Zalman CNPS 9700NT
Mobo-eVGA 680i
Bios-P24
Memory: Crucial Ballistix Tracers
2x1GB
1.9v
4-4-4-12
CPU:
E6600-Retail
L629B
1.329v at 3.6ghz - Orthos Stable
DangerDen TDX waterblock
Intel Bad Axe 2
Memory: OCZ DDR2 1000 Gold
2.25v
4-4-4-12
The system is:
E6600
Scythe Mine
Jeff
Jeff, try these settings... I have a Commando but it should be similar...
under Extreme tweeking
Manual
fsb=350
mem=700
PCI-e 1110mhz
pci=33mhz
spread spec=disable
cpu volts=1.5v
fsb ter=1.5
nb vol=1.5v
sb sata pci ect=auto
SB v=1.2 ( you might not have this voltage )
Memory voltage=2.2v
leave everything after this at default
disable the last to manually set ram timings... start with 5-6-6-18....
Advance
Under cpu config
Enable ( to enable the multi's)
disable
disable vanderpool technology
enable
enable
disable
Thats all the important settings to get a decent overclock.... Im doing this on top of my head so I dont remember what the names are on the bios but it should look familiar......
Good luck!!!
My E6600 Lapped
L632B172
4014mhz orthos stable 4 hours
1.62v ( actual )
Thermalright Ultra 120
Asus Commando
0702 bios
Rams=Crucial Ballistix pc5300 ( naked )
timings= 3-3-3-4
voltage= up there ;)
CPU
-e6600 @ 400x9
-L629F050
-1.425
COOLING METHOD
-Zalman 9700NT
MOTHERBOARD
-Intel D975BX2 (2634)
RAM
-Corsair PC6400c4
-800Mhz
-2.08
-4-4-4-12
As of this post, Orthos has run 23hrs 32mins and temps are flucuating between 56-58C per Intel Desktop Utilities.
e6600
-B2
-1.264v actual (1.3v in BIOS)
AIR
-Arctic Cooling Freezer 7 Pro
EVGA 122-CK-NF68-AR
-P23
RAM
-Corsair 8500C5D
-1060
-2.2v
-5-5-5-15 2T (Plan on tightening this up a bit)
Currently at 3400 (377.7x9) fully stable. Temps 39/40 idle 51 full load. Had it at 3800 (422x9) at 1.4v but load temps were in the 70's , which I didn't like so I bumped it down.
I'll try this :)
CPU = E6600
-stepping 6 rev B2
-1.3vCore in BIOS
COOLING METHOD = AIR
-HSF: Scythe Ninja+ rev.B
MOTHERBOARD = ASUS Commando
-0601 (I know I should update)
-1.3v to NB and FSB termination, all other MB voltages = stock
RAM = XMS2 PC6400C4
-Brand = Corsair
-Mhz = 833 or 666
-voltage = 2.15 or 2.1 (stock)
-timings = 4-4-4-12 or 3-3-3-9
3GHz with above settings.
CPU = E6600
-stepping 6 rev B2
-1.35vCore in BIOS
-1.35v to NB and FSB termination, all other MB voltages = stock
RAM = XMS2 PC6400C4
-Brand = Corsair
-Mhz = 732
-voltage =2.2v
-timings = 3-3-3-9
3.3GHz with above settings.
Thanks.
I get 5.7 with the E6600 at 3GHz being the lowest scorerer, my Seagate 7200.10 HDDs get a 5.8 rating.
E6600 Retail Week 30a
-B2 Stepping 6
-1.340 actual (1.3625v in BIOS) (1.113v in CUP-Z)
AIR
-Zalman CU9700 LED w/ the included Zalman Paste stuff
ASUS P5B Deluxe
-1104
RAM
-Corsair Dominator DDR2 800 2GB (2x1GB) @
-2.10v
4-4-4-10-3
3.698GHz
410.9MHz FSB x 9 Multi (1643 FSB)
100% Stable
Pic
I'll try this :)
CPU = E6600
-stepping 6 rev B2
-1.3vCore in BIOS
RAM = XMS2 PC6400C4
-Brand = Corsair
-Mhz = 833 or 666
CPU = E6600
-stepping 6 rev B2
-1.35vCore in BIOS
RAM = XMS2 PC6400C4
-Brand = Corsair
-Mhz = 732
-voltage =2.2v
-timings = 3-3-3-9
Why buy a Commando and not use the added voltages:confused: what a waste.....
