TheSonOfX.51
- Apr 15, 2007
I am selling my e6400 to a friend and upgrading to an e6600 now that my computer is down due to overvolting and killing the ram because of a volt mod on my biostar tforce p695 board. I voltmodded it and then had to run to work and then when I came home, it wouldnt work. I tried changing out sticks and removing the volt mod and erasing the bios but nothing worked so I am conviced it is dead (from the resistance of the voltmod, I think I was pushing 2.4 in. Oops. It lacked options for any voltage above 2.2 (2.11 actual) for the ram so I am looking replace the motherboard as well. I am looking for a motherboard with more voltage options for the ram and that can overclock to a high fsb. Please tweak this build for a maximum stable overclock.
This is what I am thinking:
Processor:
http://www.newegg.com/Product/Product.asp?item=N82E16819115003
Motherboard:
http://www.newegg.com/Product/Product.asp?item=N82E16813128012
Ram ideas (help me pick):
This is the kit that I killed and if I successfully RMA, I will then have 4GB - http://www.newegg.com/Product/Product.asp?item=N82E16820231065
I have been looking at this because of D9 chips and I will just sell the RMA'ed G.Skill (if it works) -
http://www.newegg.com/Product/Product.aspx?Item=N82E16820146108
Northbridge Cooler:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835109128
I am willing to change any of this in order to get a higher overclock. Just try to keep the price down
I am looking for the highest possible overclock and will be running it with my Storm and thermochill 120.3. I will not be running it SLI.
Processor:
Motherboard:
Northbridge Cooler:
