BillParrish said:Depends on what you used to measure it but in general that is about right and nowhere near the thermal maximum. Around 60 to 65 C under full load is my comfort zone for my chip.
Others can and have run it hotter but I am conservative.
thats a good overclock on stock voltage and if you are happy at that speed I do not see the need to give it more voltage unless stability problems arrise. If you want to give it just a bit more voltage it probally wouldn not hurt nor increase your temps much however its hard to argue with "if its not broke, dont fix it.".
kam03 said:with core temp i get core1- 71c core2- 68c full load and with easy tune 5 i get 60 c full load, which one is right? should i be worried if the 71c is the correct one?
What HS are you currently using?kam03 said:My Intel Core 2 Duo E6600 CPU reaches 60c on full load @ 3.06ghz, is that too high?
I'm also running it at default vaultage on 3.06ghz, do i need to increase it or just leave it on default (auto)?
Thanks
