E6600 CPU power pin
AliceCooper
Ok so i got all my stuff and i need help with my PSU and CPU...... My PSU book says if i have a dual CPU system i need the 8-pin power connector but if not dual "CPU" then use the 4-pin. Then later says some "Higher End" processors may need the 8-pin and my intel box says nowhere on it what to use. So for my E6600 shall i use the 4-Pin or the 8-pin connector???:confused:
Power Supply : Antec True Power Trio 650Watt
