feanor1024
- Aug 11, 2004
I'm going to upgrade the system in my sig in a week. I was thinking...
Core 2 Duo E6600
ASUS P5B Deluxe/WiFi-AP
Thermalright SI-128 and SILVERSTONE FM121 120mm
EVGA Geforce 7950GT 512MB
I'm not sure about the memory, but I was looking at these...
Crucial Ballistix 2 x 1GB DDR2 1000
G.SKILL 2 x 1GB DDR2 800
mushkin 2 x 1GB DDR2 800
I'll use my current power supply.
I'd like to overclock as far as I can on the setup, so I want at least DDR2 800. Is there any better RAM for under $350? Is there a better video card for under $300? I don't know how ATI compares, but the 8800 series is more than I want to spend.
My case has 2 120x38mm side panel fans, so I don't think one of those tower heatsinks will fit.
Core 2 Duo E6600
