e6550 Overclock
I would definitely say you've probably pushed the RAM to its limit. I mean it appears to be ddr2-800 though just because that what it is rated at doesnt mean it cannot go higher obviously, but you are basically running it at ddr2-1000 speeds which ain't bad. So at this point, your ram is definitely going to be holding back your OC.
3.5 on a E6550 is fairly easy. My old rig ran one there 24/7. Mine topped out at around 545 or so FSB, though I never could figure out if it was the Ram, Mobo or CPU hitting it's limit.
