E6420 + Gigabyte 965P DS3 OC tips
nismohks
i have just got:
gigabyte 965P DS3 v3.3
geil ultra ddr2 2x1024 cas 4
e6420
where should i start if i want to overclock? any bios settings or things i should look out for?
thanks
What should i set the System Memory Multiplier (SPD) to?
in that Overclocking thread it said to put it as 2 but in other sources i have been told 3.
any idea?
It should show you an actual memory speed rating dependent on what multiplier is chosen.
For a basic overclock I would go with:
FSB 400 x 8 =3200 MHz
CPU = 1.40 volts
Memory = 2.1 volts to 2.2 volts
I like using MemTest86+ v1.70 to get a good initial idea of what memory is capable of and at what voltage.
If your memory is DDR2-800 then set a memory multi of 2 that lets your memory run at DDR2-800. If it's rated at CL4 at this speed then set it to CL4-4-4-( 12 to 15 ) otherwise use CL5-5-5-(15 to 18 ).
Once you are Orthos stable you can decide to go further or stick with what you got. If you are going to stay at 3200 MHz you will probably be able to reduce your CPU voltage down to the Intel default of 1.325 to 1.350 volts. It's better to start with a little too much than not have enough and immediately hit a wall. 2.1 volts is a good minimum for DDR2. Even cheap DDR2 memory factory rated at 1.8 volts should respond very well with some additional voltage.
My E6400 runs pretty happy at 425 X 8 = 3400 MHz. CPUz reports 1.392 volts at this speed while running Orthos. Choose the speed and temps you are happy with and you are pretty much done. The DS3 / C2D is very easy to get good results from and should be very stable even when overclocked by 60%.
Nice advice; let me add, my new, 2nd build with the Rev. 3.3 and a newer, February, 2007 E6600 requires more voltage. I think during the switch to another factory (Sinapore, or where ever) they lost some overclockability regarding voltage. My new E6600 requires me to stay at 1.4 volts; my 2006 E6600 could to 3.2 easily down to 1.35 volts (not the new chip!). Anyone have similar experiences?
