Yeah I am in same boat deciding. Waiting till Monday i think to make a decision.
By the way, the E6420 is under $200 as well.![]()
Mwave has the E4300 for $117 bud so, might look into that. They also have the E6320 for $169 and the E6420 for $189.![]()
whats the 6320s multi and 6400 etc etc?Do not get an E6300 - the 7x multiplier will rape you.
E6320/6300 are the same man. Both are 7x. E6400/6420 is 8x.
I know, I love the E6300 price but that damn 7x multiplier.....
What do you mean? Great results ocing the E6300/6320?
It is not about the cpu man. What you are missing is, ocing a cpu with a low multiplier very high puts a lot of stress on the motherboard and on the memory. If you have noticed some people talking about their motherboards dying? That is part of it. If you look at some of those people who have said their mobos died, alot of them had the E6300 and were running like 3.6+ghz
The CPU will overclock fine, its having to worry about the mobo temps and memory. A little less to worry about with 8x multiplier. Or E6600 which has 9x. Or the E4xx series which start at 9x.
Yeah. Now keep in mind, this is all relative and related to high overclocking speeds. IF you DONT plan on ocing past like 3.0ghz, I wouldnt worry as much and a E6300 is fine.
Im saying, you have to worry less about cooling/FSB speeds on the motherboard and ocing capabilities of the memory, if you choose a higher multiplier CPU such as an E6420 or E6600.
If you pick a E6300, it has the lowest multi out of all C2D chips at 7x. You now have to worry about the FSB speeds and cooling on the motherboard a bit more(Some mobos max out at 450ish FSB which can also prevent you from ocing the cpu higher.) As well as memory capabilities.
Dont get me wrong, a E6300 is a great cpu, and I am actually considering getting one(Not sure yet), but id say they are more for people who want a mild overclock and dont need 3.4+ghzI will most likely only need 3ghz or so, so I may go with the cheapest solution. Im still debating heh.
Okay, I was able to figure out the multiplier for all the C2D CPUs. The 4400 has a 10, good for people with less than average memory. So, that means it will work well with my PC6400 memory (PC3200x2 or quad*200) which is the FSB of this CPU. So, I know that in order to use a FSB higher than my memory is capable, we use divider, does it reduce my system's performance if I use a divider (meaning not running 1:1)?
if your ram + motherboard are up to it, the e6320 seems to be best choice. im looking at abit QuadGT + G.Skill F2-6400CL4D-2GBHK. 7x500 should be within reach, although i personaly will be happy with 7x429.
So.. you're suggesting that running with a 500FSB is the best option, when you plan to have the CPU under a constant 24/7 load?Ever hear of the terms 'duty-cycle' or MTBF (mean-time-before-failure) ?
EDIT: Sorry, it wasn't the OP that was planning to fold 24/7... so my original comments were directed at jws2346.
WHAT!!! I'm not quite sure I understand what this (to me anyway) "snide" remark
means. I was asking general questions about something I wanted to know. I was under the impression that if you had a question about some topic related subject rather than start a new thread you were to ask it on an existing thread, because it keeps things simpler without so many threads discussing the same thing. (maybe I was wrong)
