Setup:
E6400 w/ Scythe Ninja
Asus P5b Deluxe (non wifi)
2x 1gb G.Skill DDR2-800 http://www.newegg.com/Product/Product.asp?Item=N82E16820231098
I think I've set everything to how it should be. Set volts that were on auto to their normal volts. Disabled all speed throttling and crap. I've gotten the fsb up to 355 and I know i can go farther.
My problem is when I try to do an Orthos test, the cpu does fine if I do CPU only, but when i do tests that test RAM, it fails within seconds.
I've set the timings to the default for the RAM and have given it volts from 1.8-2.05.
I'm not even up to the stock RAM speed, but I think its the reason for failing.
Does anyone have any suggestions or a list of settings that I should check in the bios. Should I loosen the timings, give it more volts?
The Ninja keeps this E6400 nice and cool, how much volts should I be giving it aiming for 3.2ghz
