Hi, I wanted to know what you guys think I should do.
I currently have my rig at 3ghz (375x8) stable for Orthos overnight (8 hours, manually stopped it). VCore is set to 1.3875 in BIOS but CPU-Z reports 1.304v on idle and 1.264-1.288V on load. Temps are 36-37C idle 48C load.
my RAM is Corsair XMS2 PC5400 DDR2-675 and is rated at 4-4-4-12 @ 1.8v. It has the heat spreaders on it.
I have it currently running with 1.9v and set to 4-4-4-12 @ DDR2-750. Orthos (8 hours) and Super pi 32M stable.
I tried last night to set FSB to 400mhz (DDR2-800) and I left the RAM @ 4-4-4-12 @ 1.9v. It passed super Pi 1M but failed Super Pi 32M. It also fails Orthos Blend in <10Min. Same result with FSB to 401mhz, and I also tried giving the RAM 2.0V and VCore 1.4V in BIOS (1.32 in CPU-z idle), still same problems.
Do you guys think it's my RAM (ocing too much) or is it something else? I don't want to have to up the voltages too much, but I see a lot of other people running their E6400 @ 3.2Ghz.
