I'm running:
C2D E6400
Gigabyte 965P-DS3
2GB OCZ Platinum Revision 2 DDR2 800 (OCZ2P800R22GK)
I just replaced my stock Intel cooler with a fanless Scythe Ninja, and I'm having some issues getting my system to boot with any OC whatsoever. Temps are down across the board (CPU's running between 40 and 43C), but whenever I try to overclock it (usually 8x325), I save and exit out of the BIOS, my fans spin up like the computer's starting, and then it turns off. Five seconds later, the fans spin up again, and then it turns off. I break the cycle by pulling the power cord during one of the times it's "off", but after I do that, it always goes back to whatever multiplier I had set x 266. Not sure what to do; not sure what's causing it to spaz out, so I thought I'd bring my question to a wider audience.
C2D E6400
Gigabyte 965P-DS3
