I have a D805 on a Gigabyte DS-3 with 1gb samsung DDR2 400 ram. Been running a couple of months. I got an E6300 and when it boots up it will go for only a couple seconds then shut off then turn back on after a few seconds and do the same thing again over and over. I put the D805 back in and it starts fine. I removed all the ram and started it with the D805 and it did the same thing. Put the ram back in with the D805 and runs fine. Is their something I should try changing in the bios to use the E6300 with this ram or should I just wait till I get some DDR667 next week and try again?
