E6300 + Scyth Infinity Temp Questions
chargedmr2
Hi guys,
I just got a Scythe Infinity and put it on my E6300 running at 3.22Ghz with 1.325v. It definitely performs better than stock intel cooling. I have a couple of questions though:
1. Should I see a rather large delta (23c) with this HSF? Idle: 28c Load: 51c (room is COLD this morning!)
2. Is a 1200 rpm fan too slow for the Infinity?
3. Will upgrading from included thermal paste to AS5 provide a significant drop in temps?
Basically, I figured the difference between idle and load (delta) would be smaller. The temps are fine, but if they can be easily and significantly improved I would like to do so.
Well your load temp is fine, and that's really all that matters.
What are you measuring your temps with? What are you producing Load with?
Have you tried TAT?
Temps are with Core Temp and loads are with Orthos. I'm with you on the load temps. They are totally fine. I'm just looking to improve if possible to get a better/more stable OC. I'm currently testing at 3.43Ghz and 1.375v. We'll see how that goes. I already had to loosen the Ram timings to 5-5-5-15.
Can someone recommend a relatively quiet (I'm not a silent freak), but decent performing 120mm fan for the Infinity. I assume that there is a point of diminishing returns when it comes to CFM. What should I look for?
I to have a E6300 using a scythe infinity cooler and I upgraded the fan to this one (http://www.frozencpu.com/products/2455/fan-15/Sunon_120x25mm_Fan.html?tl=g36c15s60) it is the same thickness as stock (25mm) so it will go on and use the clips scythe provided, it is a little louder then the stock fan but it has 90+CFM's. Dropped my load temps 3/4c...... I think it is a great fan. Also, you might want to lap your CPU and the scythe infinity cooler. The IHS on the C2D is NOT FLAT, and the scythe cooler wasn't totally flat either ;) You will see another drop in temps by doing this aswell. Good luck
