e6300 overclocking
lo.
I'm new to overclocking thingy, i managed to clock my CPU @ 2,35ghz succsesfully . I put 336fsb from bios. I'd like to go up 2,66. But the problem is, that it dosen't boot up when FSB is 340+. i did give 1,45 volt but it didin't make the difference. My motherboard is asus p5b.I have deafult cooler.
cheers
The default cooler... no good ;)
If you dont wanna spend to much on a new one, here are some good ones:
Scythe Ninja
CoolerMaster GeminII
Tuniq Tower 120
Otherwise, for best results, go with
Thermalright Ultra-120 (Extreme)
Enzotech Ultra-X
load temp was about 50(5) as i remember... but i think i should get more with deafult cooler or not? I think changing the cooler change the thing. 2,66 should come izi with deafult cooler.. even 3ghz is possible...
:confused:
