Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
well i want to get an e6300 and a cheap mobo. here is my question. for 50-70 bucks, what mobo has ddr support, and decent overclocking? both of these are essential.
I dont have a mobo reco but I can tell you that any compatible mobo will have to have ddr2. Cheap mobos will most likely support memory up to 667mhz. The more expensive boards will support ddr2 800.
Sorry dude all the DDR supported Mobo's are 945 or VIA based chipsets which will not overclock at all. Save the cash and get a 965S3 and 1GB KIT of PC 667 DDR2
