- Feb 13, 2006
Would I notice a big difference? Is it worth it?
No, but with that said most E0 stepping can do 4ghz with ease and that is a huge upgrade over a 2.7ghz e6300.
This.
...but it won't matter. Yes, the number will be higher. No, there will be no actual benefit to said higher number. I'm all about OCing when there are returns, which is to say when it lets you raise settings and maintain smooth, playable framerates... but if your setting are being held back by your GPU and not your CPU... OCing the CPU is jut using more power, and replacing it is just using more money. No return.
That's not necessarily true. A C2D at 2.7GHz could be a bottleneck in certain situations. It's only once you get past ~3GHz that there isn't any substantial improvement.
Thanks for the replies everyone. I think I need a new case before I can get it any higher because my heatsink somewhat sits on top of a capacitor and the case itself doesnt give it enough room to cool right.
I'd crank the 6300 up to 3-3.2Ghz and leave it at that. If you still have performance issues in games then it's more than likely the GPU holding you back. But with a 9800GT games should run relatively smooth. So who knows. The more cache in the 8400 is definately a bonus, and running at 4Ghz is nice for Source games. My old Opty 165 ran CS:S with no problems though, so I can't see your 6300 holding you back there.
I wish I could be so lucky, my E6300 hits a brick wall at 2.4Ghz and absolutely will not go past it no matter what I do!!
