E4600
TonyLee
I know the Core e4600 processor is near release. I wonder if there will be a review here on the day of release or no. I'm curious how it will compare to an Athlon x2 6000+.
Let me take a stab in the dark for you.
Woops. Got your spleen.
If 4400 = 10x200, and 4500 = 11x200, then 4600 probably is 12x200 for 2.4GHz.
Meaning it'll be priced at $150 or $170, M0 stepping, and exactly the same as any other M0 with 2MB of L2.
Rough estimations would give Intel a 600MHz advantage (2GHz Conroe = 2.6GHz K8), so it'd probably perform roughly the same as a 6000+.
Of course, with plenty of overclocking headroom.
Taking overclocking into consideration, you might as well get the E4500 or even the E4400.
12x400mhz = 4800mhz. Maybe with phase but doubtful.
12x333mhz = 3996mhz. You could get this with phase change cooling, but you could also get 400x10 on an E4400, so why bother?
12x266mhz = 3192mhz. You'll probably get this on stock voltage, but unless you've got a stockpile of DDR2-533, whats the point? DDR2-800 is so cheap right now, you can get 4x1gb for under $150. 8x400mhz will get you 3.2ghz w/o even stressing your ram, and you can do that on a cheaper processor...
I can go on but you get the point. Unless you're using lower spec ram than DDR2-800, or intend to pair it with a really crappy motherboard, there's just no reason to buy one.
edit: and if you're not taking overclocking into consideration, i can't for the life of me figure out why. I took my E4500 to 3.2ghz on stock voltage just by dropping the multiplier to 8, increasing FSB to 400 and changing the memory divider to 1:1.
oh and before you ask, i bought the e4500 instead of the e4400 because Newegg erroneously advertised it as having Intel VT, which it doesn't.
the x2 6000+ will win almost all of the time. it beats the e6600 in most benchmarks. u can use this link to compare.
its a review of the x2 5000+ black but compares it to the 6000+ and intel c2d chips
http://www.tomshardware.co.uk/Athlon64-X2-5000-Black-Edition,review-29679.html
but obviously if overclocking the intel chip offer better value, no question.
That's the worst review I've ever seen. Who compares an OC'ed X2 5000+ with a STOCK E6550. That X2 has a 1.0GHz CLOCK SPEED ADVANTAGE.
You know what that means? That means the X2 with a 1.0Ghz clock speed advantage BARELY outperforms a C2D at stock.
Your absolutely correct! in fact, a Opteron 165 @ 2.7ghz is equal to a e4300 stock (I tried it) I never realized how much better Core 2 Duos are! I mean DAMN thats kinda sad...lol poor ati
