E4500 bottleneck with new cards?
camelass
Would my E4500 be much of a bottleneck for the GTX 280 or 4870? I'm thinking about doing a mobo swap and picking up one of these cards.
It depends on your resolution. The higher it is the less CPU you need and more GPU. I have a 4300 running at 3GHz and I'm not worried. It's a dual core and games haven't really taken advantage of it yet. If it was a single core I'd be looking to upgrade.
Sure, you'll give a little up but it is still a decent CPU. The video card remains the most important item. Here's the order you need to tackle things in:
1) Keep your E4500 CPU.
2) Upgrade the video card.
3) Upgrade to at least 4GB RAM if you don't have it already.
4) NOW think about doing something with the CPU.
+1
Also this may be useful:
http://www.digit-life.com/articles3/video/video-cpu-combinations-2-p4.html
It doesn't really talk about high end cards but you can see in their results that CPU's hardly matter compared to gains you'd get from a faster video card.
+1
http://www.digit-life.com/articles3/...ions-2-p4.html
The article's pretty flawed.
Depending on the resolutions and settings you game on. Basically if you're unlikely to stress the GPU, ie gaming on 12xx X 10xx then you're going to see quite a bit of difference. At 2.2GHZ it won't cut it though. Some people also think that high CPU power is need to maintain a good minimum and overall more consistent frame-rate. Not sure if that's true or not.
Overclocking the E4500 to 3GHZ+ seems to be the logical first step if you're planning to keep it, as the extra mhz are just free performance you can squeeze out. At the moment the 4850 seems to be the better buy than 4870, and infinitely better than the GTX280.
Well I'm still undecided. I'm either going to do the mobo/video card swap or build an entire new system around Nehalem. If my E4500 overclocked to 2.8-3ghz with the latest video card can hold me off for another year or two (if not longer) I may just do that. I was just wondering if my E4500 would significantly hold back the GTX 280 or 4870. Right now I'm gaming at 1280x1024 but eventually i'll be gaming at 1900x1200.
