Alright so I have my e4300 on a gigabyte 965 ds3 rev 1.3 and I am getting crazy temperature readings across the board. Using intel's thermal analysis tool I get around 70 degree's C load!!! on the exact same H20 cooling kit that kept my 805d @3.8 with huge voltage under 50degrees.
I am currently @3.2ghz @1.4 volts. I have reseated the block about 100 times, I even cleaned the tubes because I thought it was clogged. The radiator and the block are lukewarm to the touch at best, not 70 degrees hot!
I am thinking it is either a funky motherboard temperature reporting error, but I thought intel's thermal monitor was built into the chip? Can it still be reported wrong?
Any ideas? I'm 100% stable despite these insane temps....but how can this thing be putting out more heat than an 805d @1.6 volts!
