Skipper007
- Jun 28, 2004
I actually asked about this in Intel CPUs a couple weeks back, but I only got one reply on it, so I wanted to double check.
To start with, I have an uncle who's been thinking of getting an E6600 for his next computer. Now, he's not much of an enthusiast, but I'm thinking he might appreciate the $170 Canadian he's save (based on local prices) by o/cing a e4300 to E6600 speeds. He's lose the extra L2 cache, but I would think that's not going to be a major issue.
Now, the way I understand this, this simply requires bumping the FSB from 800 to 1066... something I should be able to do while leaving motherboard warrenty intact, since it's a speed the boards already have to support. In addition, I shouldn't need to overclock the memory and therefore will retain the warrenty on that part. I'll just lose the CPU warrenty. Is this assumption correct?
Also, I was wondering if the stock cooler is sufficient for this or if I need something stronger, since I'd like to try and keep as much of that $170 difference as possible (to be saved towards future upgrades and the like.
