Silversierra
- Apr 20, 2005
I have an e4300 and I finally got a board capable of overclocking it a bit. So right now I'm running 3.0ghz, and it's passed 5hrs(and counting) of orthos small fft. My "problem" is that the temperature reported by coretemp is VERY high IMO. It is 77C under load
, but like 35C idle. I'm using 1.4v and have the intel stock cooler installed with AS5 (grain of rice...). This seems crazy hot to me, but it is passing orthos and isn't going into "thermal protection." Is this temp acceptable? I've never wanted to see more than say 60C load on any of my cpus, but this was before these programs started using the "digital" probes, so I think these temps might be higher because it's measuring closer to real core temp. Speedfan is reading exactly 15C lower, but I understand this is some kind of "bug." Final note, the heatsink feels barely warm (slightly higher than room temp) to the touch, usually when a cpu is running 60C+ it's too hot to touch the heatsink for very long. I know the the heatsink is "snapped in" fully and is making contact, so I don't know if it's a temperature reporting error, or what's up. Any input on any of this would be appreciated. Thanks in advance.
