first off i'll start off with specs:
e4300 SL9TB 0649A111
asus p5n-e sli
2gb teamgroup xtreem ddr2 5300 3-4-4-8 D9GMH
EVGA 7900gt ko
x-fi platinum
250gb seagate 7200.10
nec 3550a DVD burner
Seasonic m12 700
stock e6300 heatsink
zalman ZM-NBF47 on southbridge
other system uses same ram and cpu
abit fatatl1ty f-i90hd
80gb wd 8mb cache special
thermaltake tr2 430
noctua nh-u9
i was planning on doing an matx setup as soon as the abit board came out. i used it to overclock my L629 e6300 to 2.51GHz (359x7). i shipped that cpu off to trade for an old e6300 i'd sold off last year (L627 that did 499x7 /w my biostar 965pt). i got impatient and after reading many successful stories on the gaming matx board forum about great successes with the abit board and e4300's i went to fry's and bought an oem one packaged in an anti static bag /w no plastic case, in a combo deal. i put it into the abit board /w 1gb of team ram, and 80gb drive. at first it wouldn't boot up, so i reset the cmos. so i go into bios and overclock it a little (2.2v on ram). not sure what the numbers were, but it was a slight overclock (less that 20mhz over stock on the bus speed because of the x9 multiplier). it locks up on restart so i turn it off and hope that the auto overclock thing kicks in to reset cmos. it doesn't. this time it finishes detection screen and errors start poppin up. i turn it off and reset cmos. i turn it on and fans/leds work, but nothing on my keyboard/monitor.
i throw the ram into my p5n-e that has a celeron 356 in it, and it detects just fine in windows. so i take the celeron out and put it into the abit board /w the same stick of ram. same leds/fans on no monitor/keyboard signal. i switch to the ram that hadn't been in the abit board yet, and still the same thing. so i stick the e4300 into the p5n-e and woolah, boots right up.
i OC by upping the rated fsb up about 50mhz each time (starts off at 800). i get it to 1000 and the bios locks up on detecting ide drives. i turn it off, wait 15 seconds, and turn it on. it boots up, i go into bios, about to load default settings, and it freezes. so i restart. this time it just keeps freezing after cpu speed detected. so i manually reset cmos. it orthos's fine in windows. so i go back to overclocking, except this time i throw in more voltage. 1.4v. i start off at 900, then 950. i orthos 950 for a 17+ hours (40*C-46*C), and move on to 1000. freezes on bootup screen. i turn it off for 15 seconds, and am able to get into bios to load default. it starts up fine, i screw around in windows while orthosing and then up it to 1000 again @ 1.45volts. freezes on bootup. so i give up. i'm at default settings right now.
i might try my asus p5b deluxe also, but i'm tired of switching stuff around, and applying thermal paste etc...
i went to a thread about a guy who couldn't get 2.9ghz on his e4300 and posted my results, but was told to make my own post. more people can see my pitiful attempts at oc'n an e4300. woohoo! well here i am. any suggestions? am in a p5n-e fsb hole? is my stock heatsink limiting me (even though i'm running at a little over 40C's)?
pics:
steppings
error message
asus p5n-e sli
EVGA 7900gt ko
x-fi platinum
Seasonic m12 700
thermaltake tr2 430
noctua nh-u9
pics:
steppings
error message
