Maybe you guys should take your geek-dick measuring contest elsewhere, this is the hot deals forum and last I checked this is called "who-gives-a-shit."
maybe you should mind your own business
Allendale, Clovertown, Conroe, Dempsey, Merom, Woodcrest all use the Intel Core microarchitecture
All Core 2 Duo CPUs use the Intel Core microarchitecture
All Xeon 5100 CPUs use the Intel Core microarchitecture
http://www.intel.com/technology/architecture/coremicro/index.htm
http://en.wikipedia.org/wiki/Intel_Core_microarchitecture
Are you arguing that architecture refers to a specific combination of microarchitecture, FSB bus speed, and cache size?
I refer to that as the platform and I use the terms architecture and microarchitecture interchangably, as it seems Intel does, and I didn't find a clear distinction between the two on their site or elsewhere.
On that, I agree.maybe you should mind your own business
all I'm talking about is the microarchitecture which is identical for both the E4300 and Xeon 5150, and is spelled out in that link to Intel's siteWould you try to tell me that a
Willamette Core, P4 1.3ghz, 400mhz fsb, socket 423, 256K cache, that uses rdram, has 180nm transistor, has no em64t, no sse3, no HT, no eist, no XD....
Is NOT COMPLETELY different than a P4 dual core, 3.73 ghz processor that has a 1066mhz fsb, socket 775, uses ddr or ddr2, and has a 90nm transistor size? (p4-ee-965)
Simply because they both carry the moniker "Pentium4"?
My point is that, since the e4300 is "allendale" core (call it a code name, if you want) with all those differences, it's NOT the same as the e6xxx's
By your logic, an e4300 should be considered identical to a Xeon 5150.
Newegg has the e4300 now for 186.
It will drop further in the next few weeks. They're just profiting on those who are too impaitient to wait a couple of weeks until prices settle down.
First: Please turn your caps lock off...a minor offence here, but before you were wild!My point is that, since the e4300 is "allendale" core (call it a code name, if you want) with all those differences, it's NOT the same as the e6xxx's
The "Basis" for the e4300 and the 5150, and the x6800, and the qx6700 might all be some "greater" group known as "Core"
but, they are NOT the same end resultant product.
If you have two people, one is white and the other is black, does that make them the same person? Just because their chram's are different sizes doesn't mean they are stupid.If two buildings, one a shed, and one a 17 room mansion, are both built out of wood, does that make them the same design?
Just because a jetta has an engine, 4 doors, and 4 tires doesn't mean it's an escalade.
Actually, there's a good correlation there.
The 2003 VW jetta 1.8T and the Audi A6 1.8T.... are they they same car? They use the same engine. They have the same transmission, they both have doors, and are both owned (that would be, Volkswagen & Audi) by the larger company "Volkswagen AG"
On that, I agree.
Second: The Allendale core is the same architecture as the Conroe core. It is the same. Would you consider the old 4400+'s and 4800+'s to be different from the 4200+'s?
Third: The e6300 is an Allendale core.
That's an asinine comment. Considering I am accentuating individual words (or sometimes a few words) obviously my caps lock button is not on.First: Please turn your caps lock off
a t2500, e4300, x6800, and QX-6700 are not the same. Don't you understand that point?Under my "Opinion" for the end resultant product of all are the same!...what?
My point was made by you.If you have two people, one is white and the other is black, does that make them the same person? Just because their chram's are different sizes doesn't mean they are stupid.
The point was, that although the VW Jetta and the Audi A6 have some very strong similarities under the hood, they are obviously not the same vehicle.Off topic enough? Anyone got a good deal for a VW Jetta?
On that, NOT I agree.
Did you even bother to read what I typed, or look at the links I posted?Second: The Allenale core is the same architecture as the Conroe core. It is the same.
No, it isn't, neither is the e6400.Third: The e6300 is an Allendale core.
IIRC the e6300 is NOT allendale. It is simply conroe with half of its L2 cache disabled.
e4300 on the other hand is allendale.
