E4300 and watercooling
TheGardenTool
I used the stock cooler on my old motherboard and the temps were unbelievably high. At 1.4v (333x9) it would idle ~65C and load ~80C+.
Now I've switched to a new motherboard and have my watercooling installed, which is very quite and no leaks! :) I've been overclocking a bit today and noticed my temps are pretty high compared to what I thought they should be. I'm idling around 45C at 1.445v with load peaking at 60C. That seems like a large delta.
Now if I remember right, I think the E4300s run hotter than their E6xxx counterparts. They also have a higher thermal limit at 100C. Is it just the processor that is causing the extra heat? I haven't had any adverse effects due to heat, and the watercooling and new motherboard is allowing me to take this chip to its limit.
I just want to make sure I haven't messed anything up as this is my first watercooling experience. It is the only part on the loop, which is the 120mm Swiftech kit.
If those temperatures are accurate they are run on the hot side. (considering your water cooling)
My 4300 @ 3.3 (367x9) @ 1.5v runs at 28c idle 50C load with a Thermalright X 120.
What are you using to check temperatures?
are you running a bigwater or something? mine idles 30C and 35 full load with my Exos 2.
Why are you pushing 1.4 to get to 3 GHz?
I only needed 1.3V. Drop your voltage, see if it's stable. That'll bring your temps down by itself.
Your temps on water are a little high.. Reseat the block, check to see how your thermal compound looks. re-apply if necessary.
