Freezebyte
- Sep 21, 2008
Ok, so I finally got sick of researching and thinking about it and just picked up a Linksys E3000 from Wal-mart and start with that. Easy to return if I don't like or failure. So far it seems to be doing well and its nice having wireless N for my Droid X with a bit more speed.
http://hardforum.com/showthread.php?t=1609713
But once again, I really don't care much about wireless range and speed as everything is wired to be gigabit in my place, only wireless is for my droid with no plans of needing wireless in the near future for anything. Alot of people seem to really like the Netgear 3700 spec wise in comparison to the E3000 or the E4200 from linksys. i'm just wondering what would be better for my heavy gaming and moderate bittorent usage as far as LAN stability and rel-ability needs? I hear alot of newegg complains on the 3700 with dropped LAN connections. I don't care about USB storage or for printer usage either. I just want a router that will handle heavy Xbox 360 and PC gaming traffic and not lock up or crash due to load or heat and will last me years down the road.
If there is another and cheaper suggestion, im open to ideas. I would still really like to have gigabit ethernet WITHOUT buying a seperate switch, it simply makes no sense, I don't gain anything finacially buying a router and switch seperately. I'm not a fan of netgear as I don't really think of them making quality products vs Linksys but i'm happy to be proven wrong
