E228WFP VS 2007WFP
shivang222
which one should i get?? im confused... seems like the e228wfp doesn't have ultrasharp...
can someone tell me the pros and cons of each?
Shortass
What do you want it for?
They're going to run at the same resolution. The 2007wfp will look a bit clearer, have better colors, and better continuity. The 22" will have 2 more inches diagonally and is about $70 cheaper.
Just depends on how good you want it to look and how much money you want to spend.
